2011 Sedona EX
I need to replace a ball joint, but the pinch bolt holding the joint to the knuckle appears to be frozen. I thought it would come right out after removing the nut (like the videos show), but was barely able to move it using a 2 foot breaker bar. And I do not want to snap off the bolt head. Any tips for getting it out?
I've read in a number of other old threads here that this pinch bolt can be a real pain to remove. My suggestion is to use a chisel into the slot of the knuckle and try to increase the "gap" of it some.Then very liberal amount of PB Blaster penetrating oil sprayed and let soak into the area. IF your cars pinch bolt is a bolt with nut design, put the nut back on so there is just a small clearance to the knuckle (but NO bolt threads beyond the nut) and hit it with a goodly sized hammer. I've seen some cars use a splined bolt shaft to "lock" it in the knuckle that makes it impossible(seemingly) to turn the bolt out.
2011 Sedona EX
Discussion Starter #3 (Edited)
Thanks. I have tried all of this, but to no avail. I am getting ready to concede defeat and take it somewhere. But... I was thinking that if I happen to snap the bolt head off while trying to make it move, I could put a steel sleeve over the other end, then thread on the nut, then drive it out with an impact (i.e., drawing the broken bolt through the knuckle towards where the nut is) . But my fear is that the bolt is so frozen in there that that would not work, which then would necessitate having the vehicle towed, adding yet more to the cost of having someone else do the job (not to mention the cost of possibly having to replace the knuckle if the shop was unable to extract the bolt).
2011 Sedona EX
For the benefit of others who might find themselves needing to do this, I finally got the pinch bolt out by using liberal amounts of penetrating oil. Had to work it back and forth in very small amounts until it finally became loose enough to tap out. Getting the ball joint out of the control arm was a different story. Even after removing the arm from the vehicle and placing it in a vise, I was unable to pound out or press out the ball joint (although I admit that I used only a large C-clamp to try to press it out -- probably not enough leverage). Ultimately, I replaced the entire arm (the new arm comes with the ball joint already installed). Cost: $85 for a new arm with ball joint vs. $35 for a ball joint alone.
Thanks for posting back, yup without the proper equipment they can be a "bear" to change. The plus side is you also have new bushings in the replacement control arm. You should do these in pairs though, same with the ball joints.
