I just bought a 2009 Borrego 4X4 EX V8. I'm trying to install a break controller but can't find the connector.I read that is supposed to be by the parking break. Does anyone have a picture of the location?
2009 Borrego EX 4x4 V8
If you are still looking for a reply, yes the brake controller wiring harness connection is located under the dash near the parking brake. I don't have a picture but I do seem to remember having to fish it out from behind a cavity behind the parking brake and it took a bit of doing. You should also consider moving the 7 way connector for the trailer wiring closer to the hitch. I found the factory location to be too far under the vehicle and a sharp right turn would pull on the trailer wiring. It was easy to do as there was a fair amount of wire to play with so I ended up clamping it to the frame near the hitch receiver.
'09 Kia Borrego Limited V8 2WD, '08 Kia Rondo, '09 Honda Fit, '67 Chevy PU
Hi anasby195,
Did you find your brake controller pigtail? I put a brake controller on my new to me Borrego in December. That darn pigtail was buried behind the plastic panel just to the left of the parking brake. I hope you are good to go!
Take care,
Dean
