Vendor
HID conversion kits have gained a lot of popularity over the years for being the easiest way to improve your nighttime driving experience, and give your vehicle an upgraded custom look. If your Kia is in need of this upgrade, Lumen LED Headlight Conversion Kit would be perfect to cover all your needs.
Built for impressive lighting performance, this kit has reliable shock, vibrant and heat resistant construction. Lumen LED headlight bulbs will allow you to see further ahead so you can easily spot vehicles, pedestrians, or obstacles in the distance - you’ll have plenty of time to steer or brake appropriately, and drive with confidence and a greater sense of security. It install directly into your headlight housing sockets and attach to the factory headlight wiring connectors with no modification required. Once you install them, you'll be impressed with that cool blue-white 6500K light they provide. It not only ensures better visibility, but also gives your ride a head-turning look. Capable of running constantly without any issues for up to 50,000 hours, this is the most efficient lighting solution you were looking for.
Watch this video with details review on Lumen Headlight and Tail Light Bulbs:
Lumen® - LED Headlight Conversion Kit
Get years of life and much better coverage on the road with Lumen LED Headlight Conversion Kit at CARiD!​
