1 - 7 of 7 Posts
2008 Sedona EX -- L
I am going thru low beam headlights (H11B) and it is extremely annoying and expensive. I just want to put LED's in and hopefully never have to replace them again. I am looking for 1.) best fit 2.) least expensive 3.) About the same brightness as OEM, I don't want to blind other drivers. Any recomendations? thx!
Kia Sedona 2006 EX
I have used LEDs for 1+ years in my Prius; not Kia Sedona. Here is my experience:
LED life: LED retailers brag about long life; partly true. However, many LEDs have fans to keep them cool; these fans are likely to fail eventually, and overheating LEDs will fail consequently. I do not recommend buying LEDs only based on retailer's claims of 10,000 hours vs 20,000 hours of life. In 1 year, I had 1 LED bulb fail compared to 3 halogens on Prius.
Brightness vs inaccurate LED light patterns: Many Amazon reviewers brag about brightness; however, I've tried three brands; they have slightly better lumens, but not much. The perception of brightness may be associated with false light pattern with an inaccurate placement of LED-filament (LED-bulb). The false light patterns also shot blinding bright light on oncoming traffic; not safe. Of the three brands I tried, all three claimed to have H4-compatible LED bulbs. However, only one had correct H4 LED-filament placement (Katana H4 on Amazon) consistent with halogen filament placement. I recommend buying LED bulbs that have LED-placement geometrically consistent with halogen filament placement.
LED fan noise: LED fan are, in some cases, are noisy. Notable on a hybrid; probably not so much on a non-hybrid. LED with a noisy fan likely to fail soon.
White/Yellow color: I prefer yellow colored light over white-light. In the medical community, there are concerns that exposure to bright white light may be linked sleep disturbances, namely insomnia.
Sedona 2010
Your failure rate is high. I would think something else is going on. It may be possible you have recieved poor quality bulbs but I would look for a poor wiring connection causing more heat build up than normal.
2008 Sedona, base model.
My impression has been that it is impossible to get proper light distribution with LED retrofits in a system designed for halogen (filament) lamps. My only experience is putting LEDs in a 2005 Subaru Outback (low beam, projector setup). There is some improvement in visibility but the cutoff is fuzzy, so I would not be surprised if other vehicles might be annoyed.
I’ve seen some LED bulbs where there is a screw to loosen, and then the bulb assembly can be rotated into different positions to try to get them properly aligned.
I've put Katana H11 into Forte and H11 LED bulbs usually can be used where H11B came from factory like in my Sportage, I did have to slightly modify the connector inside headlight in Sportage.
Imho, Katana bulb is a better choice over Alla.
Also, some bulbs work better in reflector headlight and others in projector one:
www.bulbfacts.com
1 - 7 of 7 Posts
