leaking thermostat
1009 Views 4 Replies 1 Participant Last post by  anarky321
had to take the new thermostat out after barely 5 days because it started gushing - has anyone put one in on this car? I don't know if the problem is the gasket on the thermostat because it seems like there is already one on the plastic outlet pipe
so i found this on the internet....interestingly this isn't mentioned in the repair manual
See less See more
  • Helpful
Reactions: 1
the solution turned out to be even simpler - as we bought the car without a thermostat I didn't realize this gasket was missing - the same gasket costs $3 at kia dealer and $10 at hyundai dealer
See less See more
edit: ok turned out it wasn't leaking
adding that gasket seems to have solved the leaking issue
well here i am back again with leaking thermostat housing......anyone got any tips? water pump gasket maker?
i know that taking the thermostat out completely resolves the leak issue but I also feel like that's a bad solution
to be clear the car came without a thermostat - a fact we found out when we went to replace it
trying to put a thermostat in without the gasket results in a leak as there is nothing centering the thermostat on the housing without a gasket there ......with the gasket it wasn't leaking for a while but now it is
maybe blue rtv on the 2 bolts? water pump gasket maker on the gasket?
