Greetings,
I'd try to use a fine wire brush to remove the accumulated dirt & scale on the fitting end down at the release cylinder @ the trans housing, and lots of PB Blaster / penetrating lubricant to loosen up the fitting, let it soak in overnight..
*Be sure to use a good quality flare-nut wrench to remove: a combo-wrench will most likely strip the fitting..
HTH & Regards,
GottaCruise
