1 - 7 of 7 Posts
Kia Sedona 2.9 TDI (51plate)
Ok, so my 51 plate sedona 2.9TDI that I have had starting problems with for a while now, finally died at tesco car park, had it recovered and taken to a garage and they have said the injectors are stuffed. They seem reluctant to do the job as they believe it could run up a bill more than the car is worth.
Any suggestions on getting this done on the cheap?
2003 Sedona 2.9 CRDi, 1992 2.5 Mitsubishi Pajero LWB, 1998 Toyota Corrolla, Suzuki GSXR600
Nope. I had to buy 1 injector when a valve decided it had had enough and caused some major damage to the engine. The cheapest I could find at the time was from a dealer near Newcastle I believe, it was still £170 though. You could try ebay for salvaged ones but the quality is unknown so could be a false economy. The only other option is to remove them and try a specialist to see if they can be reconditioned. I think the one in my car are made by Delphi.
Banned
if as you say its the TDI version then try sedona gary , you can just swap the injectors out on this model
Anyone know what size adapter I need to pull the injectors out?
Banned
They either fall out or are right bugger to get out. I had an old spare one which I took to a local nut and bolt shop and asked if he had a nut to fit the thread on the injector. I welded he nut to a mates slide hammer and spent 20 minutes on 3 of them and a day and a bit on the other one. Dont try to unscrew them anti clock wise as the injector is in 2 parts and will unscrew and leave the bottom part stuck in the hole. I'll have a look at the weekend and see if I can find the other nut as I did buy 2 of them.
Discussion Starter #7
So, am all good to go on this job, but ive been told that i might wanna stick new pipes on the injectors while am at it as there not supposed to be re-used, anyone know the part number or supplier for new pipes?
1 - 7 of 7 Posts
