Tried to look-up the procedure how to change the fuel filter on a '05 Sedona on kiatechinfo.com.
Here's what it says:
Remove the fuel tank cap to lower the fuel tank's internal pressure.
2. Locate access cover.
3. Remove the fuel pump & fuel filter assembly installation screws, then remove the fuel pump & fuel filter assimbly from the fuel tank.
Really? This has got to be the worst description I've ever seen!
Does not say where the access door is.
Would you not depressure the fuel system by first taking-out fuel pump fuse and run-out the fuel/pressure BEFORE attempting to open the fuel tank?
Would you not remove the negative battery cable when doing this?
Or is it just me? These descriptions did not do much for me. Oh well, at least the access to kiatechinfo.com is free and did not pay for these wonderful instructions.....
