1 - 20 of 40 Posts
2004 Kia Sorento
2004 Kia Sorento automatic with TOD transfer case.
History is this. I bought one year again. Transfer case has 165000 miles on it. It was never serviced or worked on. I bought cheap because transfer case was clunking at take off and up to 35 mph. Removed tccs fuse and no more clunking. We drove for a year. Probably 7000 miles or less.
Last week I pulled apart transfer case and cleaned thoroughly. Replaced the clutch pack. Chain. Driven sprocket. Seals. And reinstalled in the Kia and filled with proper fluid. Installed a new 20 amp fuse for the tccs and unhooked battery for a few minutes. Hooked battery back up and started and warmed vehicle up for a test drive.
No more clunking. But also no 4wd and no 4 wheel low. I’ve tried proper procedure for 4 wheel low and tried a few other ways from other vehicles. Nothing.
My Matco Tablet says it cannot connect to the tccm. I have tried through the obd2 and the engine compartment test port. Both fail to connect.
I have tried a few more new fuses. I have unhooked the tccm a few times and the terminals are very clean and all looks okay. I have traced as much of the wiring as I can see without removing much of anything. All looks fine. I have not however checked for power anywhere yet.
I do get the lights in the dash when key is first turned on. No blinking. Just on for a few seconds. I do not get the lights if the tccm is unplugged.
I have no codes in any other module. So that should rule out that part. The speed sensors show equal speeds as they should. The speedometer works fine. And everything else in the vehicle seems to work the way it always has. No ghost issues that I know of.
Is there a relay behind the glove box on this model ? I’m thinking if there is it may be stuck from no use for slightly over a year ? If there isn’t a relay what are some other options other then a possible bad wire or bad tccm ? Does power go through switch before the tccm ? I figured surely the computer would communicate with tccm even if switch was bad. So o figure the switch isn’t my problem.
Any ideas ?
Any ideas ?
Don't think so (at least not that would affect this)
No. The TCCS fuse (#13) sends power over 2 lines to the TCCM
Not really, apart from the obvious (checking power). Have you checked the connector at the TCCM module is good?
2004 Kia Sorento
I haven’t checked power yet but plan to.
Should just be power on two wires going in one one plug or power on each plug?
The module is mounted pointing upwards beside center console basically. I pulled both connectors and they look clean. Very shiney and dry. Doesn’t appear to have water up that high. I however did have water in the floor pan that I am letting dry out over the weekend. But the tccm is above were the water is since its mounted up on the side.
I’m hoping it’s something simple now that the transfer case has all new parts that control the 4wd part.
Scanner should communicate with the module if the module has power correct ? If not faulty module ?
How about water round the ECU? If it is in the floorpan that is a possibility (passenger side floor, under carpet, under protector plate). Not sure about scanner communication with TCCM. That would depend on the scanner and software. Not all aftermarket scanners have that capability and may be restricted to proprietry Kia stuff over Kia diagnostics port.
The blinking 4wd lamp is, I think, reserved for EST (ie non-TOD) boxes, so would not apply here. Otherwise, here is a list of error codes attached. I think these should be available via ECU and OBDII readers.
2004 Kia Sorento
I get no codes with the new Matco scanner nor with the snap on Solus pro. The snap on doesn’t even have the tod option on it like the Matco does.
The ecu seems dry. However I know the water has been on and or around it and I had a ecu code for spark adjust. I cleaned the ecu area and connectors and got the code cleared. The connectors there though also looked nice and clean and the contacts were not corroded or anything. No real amount of grease on them though either.
The lights just come on when key is turned on like the rear of the lights. So I know the module is putting some kind of signal out. Because when it’s unplugged it and those lights did not appear.
I’ve got several other issues I need to repair on this rig. But I want to see that the 4wd is going to work before putting any more money into it.
2004 Kia Sorento
Discussion Starter #7
It has me totally stumped also. In the morning I will do some power checks and make sure what I have there. I know the auto 4wd was working before because I had the clunking noise from the transfer case and removing the fuse solved that. But now a year later it seems as if the tccm doesn’t want to power up possibly. Or I was hoping for a relay that may have just gotten stuck.
2004 Kia Sorento
Discussion Starter #8
There is two plugs on this version of the tccm. Do to know off hand where each harness goes ? I know one must go to switch and power. I’m assuming the other to computer and transfer case ?
The only thing I remember is 'yellow'! There are a lot of yellow wires involved. iirc the 2 wires from the fuse #13 to the tccm are yellow (I know they were labelled 'memory' on the schematics. Then the wire (?) to the electro-magnetic clutch (ecm) were also yellow. Unfortunately I don't have the schematics (or if I do they are buried somewhere). I know the signal to the ecm is variable voltage determined by the differential of the front and rear shaft speed sensors (hence controlling the amount of engagement and torque transfer to front wheels).
With a big leap (faith/intuition/whatever) if you can identify the 2 connectors on the tccm and see separate yellow wires on each we may get somewhere :) I am guessing wires to the supply side and control to the ecm might be on different harnesses/connectors. If you can identify the ecm connector and disconnect that, leaving the memory supply in place, that should generate a code I would have thought. Or pull the harness connector off the transfer case ecm to leave open circuits.
2004 Kia Sorento
Discussion Starter #10
I found power on several yellow wires and one orange wire on the connectors. However there is 5 or 6 wires going to my selector switch and none of those wires have power when plugged in or unplugged.
2004 Kia Sorento
Discussion Starter #11
Okay. I got way further today.
I got the 4 wheel low working. Well. 2 wheel low at this point. So I believe switch. And tccm is okay. I show to have power to the orange wiring going to the clutch. I have not checked the amount of voltage though. But I know from my test light that it’s lowe voltage from the light output.
I cleaned the electromagnetic clutch in a parts cleaner when I had case apart. Will that kill them ? Or could it possibly just be slipping ?
You cleaned the new clutch pack? What oil did you refill tc with??
2004 Kia Sorento
Discussion Starter #13
It was brand new and super clean. I didn’t brake clean it or anything. Just wipes down with clean hands and soaked for 30 minutes in the fluid I used in transfer case.
It was the GM fluid for there transfer cases with clutch packs. I will have to look at the exact name of it.
General Motors auto trak 2
The usual options we advise (UK) are genuine kia oem fluid (There is a part no in the tc rebuild TSB ) or Dexron III PLUS FRICTION MODIFIER. From my brief research it would appear that auto trak 2 has a friction modifier included, so will probably be ok. (usual disclaimers apply).
The thing NOT to do is use standard Dexron III on it's own in a TOD box. It's OK for the non-tod versions, but death to a tod box eventually. Also, change every 20k miles. Kia changed the oil spec and change intervals after boxes started failing. (around 2005 I think)
2004 Kia Sorento
Discussion Starter #17
Yeah. I did some research and actually found were Kia in United States was recommending the auto trak 2. I’m not sure what ford recommends for the 4405 transfer case that uses the same clutch pak.
I believe the problem may be that I’m expecting it to engage right away but I have read it doesn’t engage until 4mph
I don't think that is correct. From my experience (on ice) the torque will transfer before forward motion commences if there is slip at the rear wheels. Essentially if there is no slip, there will be no engagement. There are several factors that govern engagement, but slip is primary.
2004 Kia Sorento
Discussion Starter #19
When in 4 wheel low. Engine started. Should there be voltage on the clutch wire ? If so do you happen to know how much ?
When in 4Low, the transfer case is effectively locked in 50/50 front/rear drive. In order to achieve that there must be a voltage on the ecm. Full voltage in fact, since that is maximum engagement.
(Unlike the EST [non-TOD] version there is no dog-clutch)
1 - 20 of 40 Posts
