Hello members!
I have a Kia Sportage LX 2.0L 4x2 2008, i recently had the ESCOFF/ABS/BRAKE lights always ON :(, i also got this fault codes from my kia:
C1237 PRESS SENSOR SIGNALFAULT
C2380 ABS TCS ESP VALVE ERROR
C1513 BRAKE SW
C2112 VALVE RELAY FUSE FAIL
What i did is this:
CHECKED BRAKE LIGHT SWITCH
CHECKED STOP LIGHTS
CHECKED ABS ECU BRAKE AND OTHERS FUSE
CHECKED AND CLEAN SPEED SENSORS ON THE WHEELS
CHECKED SPEED SENSORS CABLES
CHECKED BRAKE FLUID
I have a new battery in my car , when i press ESC switch nothning happens , everything else is working without any problems , is there something else i can check in my car to fix this problems??
Thanks
Your Anti-Lock-Brake module is telling you a issue is occurring. Could be lots of things. Stuck valve or failed sensor, etc.
If you have never had your brake fluid 'pressure bled', please do so. Car is 12 years old.
Any good shop can do this.
Its going to cost 100 dollars or so to bleed the brakes.
ABS systems (including the traction control part) can get very expensive to repair or trouble shoot.
Start with the fluid change. Good luck.
09 kia spectra ex,'11 Dodge Journey AWD,04 Chry. T&C, 08 Pontiac G6 gt
I have a 2007 Kia sedona EX and the brake lights are always on.
Wrong vehicle page. You are on a Sportage page posting of your Sedona.
Can't say for sue as to fix, but would start out by checking/replacing the brake light switch at the brake pedal.
Good Luck!
