kia sorento 2018 lx 2.4 4 cil
hi guys how are you i have kia sorento 2018 doors wont unlock or window down from driver door switch
i scan it with lauch and ADM passeger door module no comunication
somebody have idea where i can find ADM door module
thanks
2016 Sorento EX 2.0T AWD
All doors won't unlock and lower the windows? or only the passenger side?
thanks for reply
Only open the driver's door, from the driver's door I cannot up or down the rest of the windows I cannot remove the lock from the rest of the doors ,the trunk door wont open
but if I go to the rest doors eg passenger door and press the button to raise or lower the window, yes does it
y check fuses
I have a launch x431 scanner and the only module that has no communication is just adm is the passenger door module ADM MODULE ADM : Assist Door Module
Those symptoms also tell me it could be the DDM (Driver Power Window Module). Otherwise, all other locks and windows, except the passengers', would be working.
The DDM module is basically the windows switch panel on the driver side. The ADM is the window switch on the passenger side.
118830
118831
To remove them, you would need to remove the door trim, then remove the screws underneath the switch.
see attachments for instructions.
Hope it helps.
THANKS man
2020 Sorento SX, 3.3L AWD
For a 2018, isn't this a warranty item?
