I recently have had trouble with my 2004 kia sorento's engine not starting. I believe it is the crank sensor. I would like to know what is the resistance on the crank sensor. Thanks.
Eddy
89 Isuzu trooper, Subaru Forester
The best way too check the crank sensor is to measure voltage between ground and pin 3 (you will have to back probe this) on the connector (should be a single terminal above 2 adjacent terminals) You should have 5 volts, If not the crank sensor needs to be replaced.
