2001 Kia Sephia
Hi!
Looking for help so I can finally get this darned thing running.
Battery has been dead because it's been sitting.
Once I jumped it and started the engine, I noticed that drip, drip, dripping down directly into the alternator components below.
Here's a picture of where it's leaking from...
What should I do?
2001 Kia Sephia
I did some research and see that it's called the "fuel pressure damper" or "regulator", etc.
Can I tighten this or do I need a new one?
If I need to replace it, I'm going to leak fuel everywhere right?
Are you sure it is not the fuel hose end that is leaking and making it look like the unit leaking? With no info of actual year and age and where the car is lpcated on the planet(Earth?), makes it rather hard to give good advice.
As for opening things to replace, the fuel will spurt out only if the system is under pressure from a recent cranking over.
2001 Kia Sephia
It's a 2001 Kia Sephia, sorry for not clarifying that.
There's only one hose connected to this fuel pressure regulator in the picture, and that is the one with the green band on it (see what I'm talking about?).
The hose with the green band on it... I was under the impression that this is just a vacuum line, no?
The other line (thin and black) in the picture I am pretty sure is only in close proximity but unrelated to the fuel system.
I just ordered a new FPR for $25.
2001 Kia Sephia
Discussion Starter #6
The top of the FPR looks like a top hat as shown in the picture. It's definitely dripping from around that area. The "rim" of said top hat.
