2000, Kia Sephia 1800 cc , automatic transmission
my car after sitting 3 month , crank but no start
look at diagram
1. ecu provide ground to fuel pump relay , it is ok , no problem
2. check continuity from ecu ground ( pin 85 fuel pump relay )which provided by ecu , it is ok , no problem
3. check voltage from ground to battery plus ,,,, there is no voltage between ground ecu and battery
whats wrong ?
...there is no voltage between ground ecu and battery
whats wrong ?
Maybe a burnt fuse.
You'll need to check connections, fuses, relays...
