Kia rondo 2016 audio unit installation
599 Views 1 Reply 2 Participants Last post by  Leukopla Kia
Hi, i recently had an issue where my audio unit did not turn on, checked all fuses related to the system, i have voltage ground and acc going to the unit correctly, after 20 minutes of driving around the unit turns on. My question here is, what dash kit do i need to replace my audio unit for an aftermarket one, and where to buy it. I am located in quebec canada. Thank you
You just have to do a basic search for "car stereo dash kit 2016 Kia Rondo"
2016 Kia Rondo Stereo & Video Installation Parts — CARiD.com as an example.
I can see why you ask that because I wasn't able to get any good results that particularly inspired confidence. Where is the one for a single-DIN aftermarket? Normally you'll see obvious custom-made trim pieces to fit the unique outline of the factory one, and then a slender perfectly rectangular shape cut out in the middle for a tight fit on a new, modern unit.
Alternate solution is to get another factory original unit from a few sources, whether eBay, Amazon, or a local parts yard (which can be searched with car-part.com)
You might also consider it could be a weird wiring issue with a loose harness or metal contacts that expand just enough to work once they warm up or get enough vibration to seat into place after 20 minutes of driving.
See less See more
