1 - 8 of 8 Posts
Hi, i have a kio rio 2001 rs the temperature gauge is going to hot but the car does not stall or steam, the fan work, fuses are good, preston in the radiator and also in reservoir. When i open the hood the motor does not feel hot. When i was driving the gauge when back to normal then back to hot when i stop at a light went back down. If anybody that happen to them also please replies to this message thanks.
bad thermostat? stuck closed?
2001 Kia Rio 5-speed
could be a weak ground on the temperature sensor.
they use a negative resistance setup.
does it go hot right when you turn on the car? or after a while. if right away, then sensor could be screwed. if after a while, check thermostat or water pump (when changing water pump, change timing belt at the same time, and make sure all gears are cleaned up good! )
1 - 8 of 8 Posts
