Hi
i have a kia picanto 2005 1.1 and i have no brake lights at all,first of all i have checked the bulbs they all work ok when powered directly off the battery.I have also checked the mini fuses and the relays with no luck,I have also changed the brake light switch and they still dont work.i was wondering if i may have a disconnected/broken wire?does any1 have a wiring diagram?
can any1 please help
kind regards leigh
2010 Pica Graphite
I am searching for the same thing, information on Pica's seem unusually difficult to get hold of.
If I find anything I will let you know
Same problem
I've got the same problem on mine.Checked everything including linking the brake light switch......Had clutch replaced about a month ago & was wondering if a connection was forgotten or been knocked causing this.....HELP PLEASE! Apart from chasing the loom all the way through to see if there's a fault in it, am at a lose! :mad: :confused: :unsure:
