Sorry, yet another KIA horn post. I've searched the forums here, and in general for wiring diagrams. Problem; the Lo horn (passenger side- Right or Left? Is it anything under the hood that seems reversed?) .... has quit working. Thanks to my better half and a disagreement with a curb, a hold was created in the right front wheel-well. I was able to reach up and disconnect the horn. The Hi-note (driver side) works. Obviously the fuse is good, and the "secret' hidden relay must be working, also.
I bought 2 horns, and a new harness for 2 horns just to get the male plug that fits the original plug pulled off the bad horn. Today I was preparing to create new wiring using the 12V from the Lo horn leads to trigger a new relay, which would then provide the 12V to the new horns, with a separately fused power lead from the battery.
Good that I thought to test the original leads for power before going too far. You guessed it. No power from either lead when pressing the horn on the steering wheel. I have no interest in now checking the Lo-note horn to see if it actually works, using a jumper lead. I want to install these 2 new horns regardless, improvising the mounting. And I don't care what pitch the working horn is.
I suppose my only option now is too track down the wire from the module containing the relay, which leads to the working horn. Then find a convenient location to tap into. I want to use it trigger the new relay so that an excessive load isn't added to the existing horn circuits. The new horns and wiring call for a 16 amp fuse.
The 2 wires attached to the horn plug are Black, and I believ *solid Green. But I'm aware that often wiring from the brains under the hood pass thru various connectors. So, I'm wanting to locate a diagram showing the complete horn circuits.
