Kia Cerato
Hello, my cruise control (in KIA cerato ex 2005) isn't working. I can only turn it on and cant set anything else.
What could be reason for this problem?
And sorry for bad english
05 Kia Sorento LX 4x4
Check for other faults. Most times Cruise control will not set if there is something wrong (check engine light??).
Another possibility is that the vacuum connection is failed, or the throttle cable from the Cruise controller isn't connected anymore.
Yep... Check engine lights...Defeat switch on brake and/or clutch pedals...Speed sensors on ABS models. The servo assembly mounted on the right front fender can also go bad or the cable to the throttle body can come off.
Newer cars don't use vacuum to pull the throttle open,,they use a servo motor.
