Kia Ceed CRDI16v
Hello I have recently bought a 2006 kia ceed (used) and I have found out that for me to shift from 3rd to 2nd I have to clutch neutral unclutch then clutch 2nd
Is that a "feature" or is something broken
Thanks in advance
That is called double clutching. Try a trans oil change first. But, sounds like your blocker rings are worn and your not able to bring the speed gear up to synchronization speed. You may have to continue to perform this maneuver as long as you own the vehicle. Its okay to do double clutching, and your smart to figure that out! Good luck!
