Kia Carens UN 2.0 CRDI- Problems
3953 Views 4 Replies 3 Participants Last post by  Lou O.
Hello everyone,
I have bought a used 2006 Carens 2.0 CRDI - 140HP diesel Automatic and I'm pretty happy with what it offers for the price but there are several problems I noticed even tho it had service manual and regular checks.
1. There is a strange phenomenon happening when I'm driving at around 50km/h with constant acceleration. The rpm is about 1-2k but then it gets out of gear, drops rpm and starts to accelerate again. This happens over and over until the oil warms up (I think). There is no problem when I'm flooring it at any speed and it pulls hard and smooth.
2. Cruise control does not engage regardless of what I do. The cruise sign on dashboard doesn't turn on.
For point 2 I have managed to turn it on after I've erased the DCT codes. The light came up but as soon as I've started the car it went off and never worked again.
As I've mentioned the DCT, I should also mention the codes associated(read with a cheap OBD2 module). There was also a check engine light that sometimes is up but mostly it stays off.
P0700 - Transmission control Module MIL requested
0741 - Torque Converter Clutch Circuit Performance or Stuck Off
OOE4 - Unknown Trouble Code
1406 - Custom Error Code
After I've cleared all codes, the only one that stays is 1406.
As I've read 1406 is related to EGR valve. I'm gonna clean it next week just to be sure.
Does anyone have any experience with it? Anything I should be looking for?
For anyone who might be reading this post, problem number 1 was solved.
The problem seems to be a clogged up EGR valve. After a cleaning with some strong paint thinner it's working excellent.
  • Like
Reactions: 2
my cruise wouldn't work unless i tap the center of the steering wheel whilst switching the on button . I also have an airbag light on that is related to the clock spring , so its probably the clock spring . i did get a new one from ali express for £6.50 but have not fitted yet .
I did figure out eventually it was the clock spring and ordered one. Will fit it and probably everything should be good since airbag light came out too
Good work! Be very cautious around air bag inflators! They can kill you!
