Kia Carens
:(Can anybody help please? i am a new member and would welcome any advise. My problem is: My windscreen washer does not work the res is full, the jets are clear, Could it be a fuse i wonder have checked both fuse boxes and can't see any fuses for the screen washonly wiper blades.
Memorial Super Moderator
2005 Kia Cerato LD [2L petrol] manual, 1986 Nissan Pulsar hatch
Welcome to the KIA forums. I have moved your post to the correct forum for you. Is the washer motor turning at all, any sound? Have you checked if the washer motor is getting power to it? Use a test light or multimeter to check power at the pump motors terminals. I think the washer and wiper may be on the same fuse. If the motor is working and no fluid is coming out and washer jets are clear, check the following. Most Kias also have a small gauze filter on the pump intake that can block ,check for that.
Thanks Pulsar86
My Kia Carens had a problem no water coming from the windscreen jets. Did as you said, removed the three screws from under the front of the car, right side. Disconnected the pump from the water bottle, pulled out the pump filter and cleaned it, replaced. Pump now washes the windscreen no problem. The filter on the pump is very small so will block if you own this car for a couple of years.
Thanks you, thank you, thank you Pulsar86. Without your post I would have had to take my Carens to the dealer.
All Kia 2005 -2008 Carens 2000cc ignición and fuel parts
Need all parts ignición and fuel with inyectores,
including air filtración completé and computer an upper fuse box.
In need help my car was assalted and all these was taken
Can u help?
