same on my Soul, but only works with the low beams, so with the flat cut-offs of the low beams, I find it works out okay.ya nice looking car.
while you are at the fog lamps, see if you can find any way to turn them on independent of the the headlights. My fog lamps will not come on unless I have the headlights on, which kind of defeats the purpose of fog lamps....
Fog lamps used to be for fog etc, but now they are more of a cosmetic accessory. The fogs that come stock don't really compare to true fog lights from 20 years ago.fog lamps are made to be used in fog/rain low visibility situations at night. that is why they are synced to come on only with low beams. high beams make things worse in rain, snow, fog etc. they arent made to run all the time and put a pretty big pull on the battery to run them.
I have been looking all over for led fog lights. Do you have a online shop that ships internationally that I can check out?took out the stock fog lamps and put in some LED ones.. it gives sort of a Angel eye effect.. I like it.. my HID will be here Monday so they will be going in next.
