I just bought a 2009 Rio manual. 1.6 engine
1. Does the engine use timing belt or chain?
2. Is engine inteference or non-interference type?
3. What is a sensible replacement time/mileage for timing belt?
4. What is the biggest oil-filter that will fit this engine? (Instead of the standard)
5. Where is the radiator drain for collant?
6. Where is the drain and level check hole for manual trans fluid? What manual trans fluid does it use?
7. Does it has hydraulic fluid for the clutch?
8. Does engine coolant low temp gauge generally come on in the morning, as my Nissan Versa?
Thanks you
Thanks you
