Bought my 16 year old a 2002 kia spectra. His engine light came on and he didn't tell me until 3 days later when the car wouldn't move. He had run out of transmission fluid. Now that we refilled it we have no drive. Low 2 works and you can switch over to drive once you pick up speed. We have 3 codes. PO741, P1529, and PO732. Any ideas? I'm a single mother with 3 teenage drivers and really can't afford to go to a transmission shop.
moved to the right section.
Well, it is likely the transmission is damaged.
How much the fluid did you add? Who added the ATF?
Also, what is the colour of the fluid now?
3 quarts only? If the tranny was empty it should have taken more than that.
Capacity is around 7-9.
P0732 KIA
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty Shift Solenoids
- Shift Solenoids harness is open or shorted
- Shift Solenoids circuit poot electrical connection
- Transmission mechanical problems
- Transmission hydraulic control circuit
Read more: P0732 KIA Second Gear Incorrect Ratio OBDII Engine Light Trouble Code | Engine-Codes.com
P0741 KIA
Possible causes
- Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness or connectors
- Torque converter clutch solenoid valve circuit is open or shorted
- Transmission internal mechanical problem
Read more: P0741 KIA Torque Converter Stuck Off OBDII Engine Light Trouble Code | Engine-Codes.com
P1529 KIA
Possible causes
- Check for transmission codes.
Drain refill fluid, maybe will help...
Eventually do fluid flush.
If does not help - tranny rebuild as I doubt this is electrical issue (such as connectors loose or swapped)
