2013 Sorento EX V6
Anyone know if there is a trick or special way to remove the dome/map light covers?....I'm sure its simple but I dont want to break them.
open the storage for your shades or glassess unscrew the 2 star screws, pry from the edge of the assembly (close to the windshield) then push backwards then pull down..
13 Sorento LX
I think the OP is asking how to remove the clear lens to get to the bulbs. If so, use a small flathead screwdriver and they pop right off. There should be a little slot to fit the flathead in, then just pry it out.
yes, but is also the way of replacing the bulbs.. its how in the dealer's manual procedure is.. bulb is placed like the front turn signals twist and detach.. bulb is not so tightly twisted so when putting bulbs (like inserting and pulling might accidentally make them out of place) plus its easy and more secure doing this..
