On my 05 sportage the check engine bulb is bad. How do I remove the cluster so I can replace the bulb? It appears the whole dash has to be removed. Any help would be greatly appreciated.
If your vehicle matches the procedure on kiatechinfo.com, it should be pretty easy..
1. Disconnect the negative battery terminal, to prevent any electrical issues when removing the cluster connector,
2. Remove the cluster facia panel (sits in front of the instrument cluster), by removing 2 screws, located at the top of the facia panel,
3. Remove the trip switch connector,
4. Remove the (4) screws securing the instrument cluster to frame, pull the cluster out a few inches, to expose the cluster connector,
5. Remove the cluster connector.
The instrument cluster should now be free, remove the cluster.
6. Installation is the reverse of removal.
