1 - 19 of 19 Posts
Going to have this engine installed in my Sportage......
Would be a better fit in a Soul...ROFLMAO!!!!!
Have a Happy Thanksgiving!
Did you mean ON your Sportage?
Sent from my SM-N975U using Tapatalk
You had enough of the Theta II ?
2019 KIA Sorento SX - 3.3L GDi V6 - AWD
:oops: :oops: :oops:
Don't forget to also upgrade the stock tires though...
Maybe these would work??? :unsure: (y)(y)(y)
Yeah those may work...BUT then it would loose the "SLEEPER" effect on looks!
And to the prior post... 4 GALLONS PER MILE is probably more accurate.....
  • Like
Reactions: Pretender
Discussion Starter #9
He, he, he.....a little fun for Thanksgiving! I believe the engine gets 4 GPF (gallons per foot) The tires on the Nova most likely would hook up well. Most likely would lose the rear seating area after tubbing. ;)
It is SO NICE to see a little humor on the threads again!:):):):):D
Looks like two 12V-71s in-line. I guess you may know that the Detroit Diesel engines are 2-cycle. That's why they all have a blower, because that's the only way they can run. They use a conventional crankcase oil lubrication system so they don't need oil in the fuel. The blower forces air into the cylinder and the fuel is injected normally. This is timed to limit the obvious overlap where some of the fresh charge is going to be blown out the exhaust valve. No other diesel sounds like a Detroit. Another major application was the 16V-141 which has been used in practically all Diesel-electric locomotives, running a constant 900 RPM to turn the generator to power the electric motors. That's 141 cubic inches of displacement per cylinder, 19 C.I. more than the KIA 2.0L engine.
Discussion Starter #12
One smart cookie....knows his engine history. Yes, I've heard these running (in a heavy crane set up years ago) and the sound is unmistakable!
Yes he is. and I was aware of these type motors as I had trucker friends in my past that had D.D.'s in their rigs and other heavy equipment.
My hope for this obviously made in FUN thread, stays that way and not "morphed" into technical or a "skepticism" diatribe. We have enough "technical" and "purist" threads on the forum, a bit of HUMOR is needed from time to time.:)
Well there's always THIS engine...
OK, but maybe not quite that "humorous"!:rolleyes:
  • Like
GEEZ...I'll take 2 of them...Don't think even an Abrams tank could compare!
@ddhartma...I think you may be right on that!
Kia 2015 Sportage Platinum diesel and 2013 Rio 3 door SLS
Where do you plan on sitting once the install is complete?
1 - 19 of 19 Posts
