My 2010 Rio has a 1 amp leak and drains the battery (AAA test). The ignition key warning occasionally keeps chiming after the key has been removed. I believe this malfunction is the cause of the battery drain. Anyone else with the problem / cure?
kia rio 2008 1.4 ex , hyundai lanta/avante 1996 1.6 gls
check your switch at proper garage its probably fault in the ignition switch
and do not use heavy key holders its harming the ignition switch
