the waterpump went out on my wives 05 sportage 2.7 before i took apart the cams were a tooth or two off. I lined it back up with new pump and belt kit . when i started the engine it knocked loud so i shut it off . now no compression and one cam has strong spring action without plugs in .WHAT NOW:confused:
Moderator
99 Kia Elan 1.8L
Welcome to the forum.
It sounds like you cranked it with the valve timing that far off that the pistons have hit the valves - you'll need to take the head off, and if you're lucky you could get away with a head rebuild, but if there's impact indentations in the piston crowns, then best the block be rebuilt as well.
Depending on the mileage, it may be best to get a factory re-manufactured engine.
Interference motor, cannot start it if off a tooth or 2, BANG...
Sucks but should have known this if you were getting into a T-belt change.
Used motor from junk yard or ebay shouldn't be too costly, somewhere in the 500-800 range I would think.
