josh here is a digram for a sportage
2000 Kia Sportage Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White Ignition Switch Harness
Starter Black/Red Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Black/White Ignition Switch Harness
Tach Blue/Red Under right Dash at ECM (or Injector Wire)
Neutral Safety Wire Green or Black (ECM) under right Dash
Brake Switch Orange Brake Switch
Trunk Pin Blue Under Glove Compartment at ETACS
Parking Lights Blue/Yellow (+) Dash Dimmer Switch
Head Lamp Blue/Red Switch
Hood Pin White/Blue Above Glove Compartment at ETACS
Door Trigger Yellow/Green (-) Driver's Kick Panel
Door Lock Red/Green (-) White Connector behind Dash Dimmer Switch
Door Unlock White/Red (-)
Driver's Lock Green Above Glove Compartment at ETACS
Driver's Unlock Black/Red Above Glove Compartment at ETACS
Horn Wire White/Black (-) Base of Steering Column
Windows Up LF=Red/Blue, RF=Black/Blue, LR=Green/White, RR=Green/Black
Windows Down LF=Green/Blue, RF=Red/White LR=Red/Black RR=Red/Green
Check out
Stereo, Alarm, Remote Starter, Cruise Control, Navigation Wiring great site with tons of information.
