If I recall correctly, the 1.6T engine runs with less compression than most NA engines. As far as longevity goes, I've seen same engines run for many many miles without an issue ... or they fail before the first oil change.
As long as the vehicle receives proper maintenance at regular intervals, 120K probably won't be a problem
