1 - 1 of 1 Posts
2008 Kia Spectra EX
Has anyone replaced their ignition switch yet? I looked up instructions and the Kia shop manual says to remove the steering shaft, which seems like overkill. Others say you remove the three screws on the steering wheel shroud and then separate the two pieces, then put key in ACC and press little pin and pull ignition cylinder out. Then how do you get the switch out?
thanks in advance!
1 - 1 of 1 Posts
