1 - 20 of 22 Posts
Hello,
My 2002 Kia Sedona currently has 34,000 maintenance-free miles. Would like to know if someone has replaced the spark plugs and can provide instructions on how to do this task.
Sivinh
Originally posted by sivinh@Nov 25 2004, 08:48 AM
Hello,
Sivinh
make sure you buy new ignition leads because they can break when removing them from the spark plugs. The front (cylinders 1, 3, 5) are easy to get to with 3/8" drive sparl plug socket, an extension bar and ratchet. As for the back 3, put the vehicle up on stands at the front, grab the spark plug socket, a short extension bar and the rachet, crawl underneath the front of the car on your back and start swearing. 2 hands are required. First off, remove the plug leads by a small twist then pull. This is where the plug lead might break. Once the ignition leads are out of the way (yes, even though they seem to come up hard against the firewall - by manipulating them they can be removed), drop the plug socket down the hole onto the spark plug, feed the short extension bar into the hole and click it onto the socket, then feed the ratchet up to the extension bar (2 hands) and proceed to loosen/undo the spark plug. If you don't have the socket with the rubber piece in the end of it - to grip onto the plug, then you will need a thin magnet to drag them out with. Reverse the process for installation. This might seem long winded, but it's the ONLY way to do the back 3 plugs. They are also platinum type plugs, so they should last you to 60,000 - 80,000 km's, depending on the driving situation.
I have a 2002 Sedona and I agree that removing the inlet manifold is the easiest method to remove the 3 back plugs. It looks imtimidating at first but they are easy to remove with easy access. No need to lift car up, or crawl underneath the car. Once you remove the manifold, just remember to cover the inlet with a large towel of some sort to prevent dirt, plugs, nuts... to fall in :)
I have a 2004, is it the same procedure?:confused:
'04 Kia Sedona EX, '10 MBZ C300 Sport, 1.3KW Electric GoCart
Why not have a look at this video that gives step by step instructions - How To Replace Car Sparkplugs
For a Sedona, this is is only useful for the front spark plugs.
I will try to post my pics of my spark plug change soon. But I removed the intake manifold, but not the throttle linkages, when everything was unbolted, I was able to lift and flip the intake upside down and moved to the side to gain access to the rear plugs. It took about 3 hours, but the next time should be faster. I took pics, and will post soon.
Thanks,
-rob
Pictures of spark plug removal
Here are 4 main pictures when removing spark plugs in my '04 Sedona.
When the plastic engine cover is removed, the front three plugs are underneath the 3 ignition coil packs.
After taking off all of the bolts and tubes and brackets, you can swing the intake to the side. the throttle linkage is still attached.
The hardest part is removing the rear fasteners of the intake. I used a mirror to find the bolts. You will have to feel around, but it can be done.
The rear spark plug boots are connect to the front coils. Plug straight up to remove without breakage. It is pretty hard if they have not been touched for a while.
Hope this helps,
-rob
Hope this helps,
-rob
do you need to replace the intake gasket after changing plugs? And has anyone else used iridium plugs instead if platinum, iridium is supose to last 2 times longer than platinum. if so what brand dose anyone recomend.
Thanks to all the members of this forum for posting great pictures they really helped me complete a spark plug and wire replacement job on my sisters 2004 Kia Seonda. I ran into a very interesting problem so I'll be posting my own pictures to help the next DIYers faced with performing the same work.
Here is a picture of my sisters 6-cylinder engine. I've marked it up to illustrate which bolts and nuts will need to be removed. This is not a comprehensive outline, you'll have other attachment and do-dads to disconnect.
The spark plug wires were very difficult to remove. But I found with a bit twisting and pulling they popped out. The spark plug wire in the back park of the engine (firewall side) closest to the battery was the most difficult to remove.
When I pulled out the final spark plug wire I didn't see that the metal innard had dis-logged from the cable and was still attached to the spark plug. Here is a picture of what that looks like.
My next step was to lower the spark plug nut into the cylinder head. After an instant I could tell something was wrong. I used a mirror and flash light to look into the cylinder here is what I saw.
Luckily, I was able to reach down into the cylinder head with needle nose pliers. After pulling and pulling I was able to get achieve the following result (what you're going to see is the innard now sits slightly higher than the nut.
Using my finger I could cause the spark plug nut to move around a tiny bit. The sound my music to my ears; if it were locked down tight, it would be VERY hard to remove. I tried using tape to pull out the nut, but quickly abandoned that plan.
So I just kept pulling and pulling and pulling (while listening to NPR --- this is a true statement ) eventually I was able to pull out the spark plug nut with needle nose pliers and a tight grip (don't ask me how).
Once the nut was removed it was dirt simple to pull out the innard with the same pliers.
So the moral of the story is if you find yourself in the same position DON'T GIVE UP. It took me 5-hours to get these parts out of the cylinder.
Good luck DIYers!!!!
Hope this helps,
-rob
Don't know if you still log in Rob but this picture here helped me a great deal. I was able to do the fronts pretty straight forward. I was looking for direction on the rear bolts.
Picture helped a great deal.
Also bigfishz your pictures helped as well.
Thanks guys!
2001 Kia Carnival 2.5L manual & 2000 Carnival Auto
As per some other posts. (common forum discussion is spark plugs)
Recommend dielectric grease on the spark plugs/leads.
As the rear ones can especially bake on solid and damned hard to get loose from the heads
Long reach needle pliers often used to extract wreckage...
On the 2.5L KV5 engine it is possible to drop the engine atthe belt/pulley side engine mount.
(Sump then rests on lower chassis bar)
From underneath vehicle, This allows enough hand room to extract
the firewall spark plugs without removing the covering air intake manifold.
Somebody asked about resuse of manifold gaskets.
Should be okay if they were the pressed metal type and are in good condition.
I just use some smear of the no setting gasket goo on 'em.
And check you spark plug leads resistance values.
They should all be about the same - replace any odd fellows.
Hi, thanks for using the pics. I just changed the plugs again at 113Kmi, as for the metal gasket, I think it is best to change it. Around each intake hole, the metal gasket has a slightly raised area. I think it squishes down when you torque the intake bolts. When you take the intake off, the gasket is perfectly flat. I guess you could reuse it with some sort of gasket sealant in a tube. But it may take longer to clean up up the next time you do this. Hopefully, this is my last time for this car :)
1 - 20 of 22 Posts
