How To Change Plugs ? Newbie
2489 Views 3 Replies 3 Participants Last post by  ppwazzup
I'm new to this forum and until just a few minutes ago had never tried to work on my 2002 Kia Rio. But I decided to change spark plugs and couldn't even find them. I took the black cover off and there are the wires and after much effort and tearing one of the rubber tops I pulled out a "tube" that looks like it attachs to the spark plug on the other end, I can see to top of the spark plug way down inside a hole.
Is this how you change them ?? Through the hole ?? Is there a special tool to remove the rubber caps and long tubes to keep from tearing them like I did ??
Will it hurt that I tore one ??
HELP......I'm and old retired guy just trying to change plugs..... :unsure:
Status
Not open for further replies.
Yes the plugs are down there!
As long as the actual cable is intact, you shouldn;t have done any damage.
You will need the correct size spark plug socket, just undo and remove the plugs.
To get the plugs out, use either a magnetic plug socket, or one with a rubber insert, or use a telescopic magnet to fish them out, or the easiest way, use the plug lead itself.
Thanks so much for the info.
Is there a special tool or special way to remove those rubber things ?? Or do you just do it the best way possible ??
I replied to your email Robert.
Matt
Status
