2005 Kia Sorento, 2008 Saturn Vue AWD, 2000 Chevy Suburban
HI all, I'm just starting to install factory fog lights in my daughter's 2005 Sorento.
I see that the fog light rely and fuse are already installed in the under hood fuse box. I need to know where I can find the output wires that go to the fog lights (blue?) under the hood and where I can find the switching wire (red?) for the fog light switch inside.
The car does not have the factory switch, so I will need to find a aftermarket switch to turn on the relay.
I would appreciate any help you may be able to give.
Thanks in advance.
Discussion Starter #2
Just a bump.
Anyone have any answers?.
Also, is the switch to ground or hot?
I had the same set up on my 03 but it did not have the wireing. Some of the Sories were pre-wired but you had to look under the bumber where the light would have been to see the connections. If you search this site there are posts which cover this, Some members bought a new stalk that had the fog switch and then the lights were plug and play. I can't speak for the 05 but my 03 LX could not be setup that way. I would research a bit before you get to heavy in to it. Alot of the work may already have been done factory style.
I found a part number for the LIGHT LEVER ASSY 934103e010 $22-23
HTH
