I'm wanting to replace both high and low horns with one Wolo airhorn. I see the high, on the driver side frame rail, but cannot find the low.
I plan to use an additional and a fused line straight to the battery to make sure it has enough current, unless someone has done similar and convinces me it's unnecessary.
I mainly just need to find both horns. Thanks
2011 Sorento, with the four-banger
Sorento 2012
So disconnect the one horn you found and have someone blow the horn for you as you locate the other horn. Not all models have two horns so if you disconnect one horn and then hear nothing, you only have the one horn.
Isn't as easy as it sounds. Sound resonates all over when blown. This was the first thing I tried. I'll probably just leave the low horn connected. The Wolo will probably drown it out, anyway.
