Hi. New to the board. I just bought a new 2013 Sorento Ex two weeks ago. My 05 Sorento had the Homelink autodimming mirror so the wife wanted one on this one. So i bought the aftermarket online because it was MUCH cheaper. My qhestion is does anyone know the easiest way to install the mirror wire wise, hot, ground, constant without having to tap into the fuse box or cut wires? The wiring that came with the morror came with tap wires. So that helps. And help would be appreciated.
2015 Sorento
Not to beat the dead horse here, but the KIA one comes with full and correct directions. Maybe thats one of the reasons its not waaaaay cheap.
Its not an easy task to install this, kiatechinfo.com you should be able to pull up directions for the KIA one, and it may help sort out the other one you have, and may work. May.
