1 - 15 of 15 Posts
06 mitsubishi eclipce gt-se v6 106k miles , 00 sportage base 72,802 miles 2wd... purple...
if u all have been watching my posts, i have a problem 00 sportage. i recently did the rings and now it starts right up and has alot more pwr but still not as much as i had hoped. anyway since i did the rings the idle is at about 1100-1200 and i recently got a code from the iac saying its to high so i erased it and went on and the idle is still that high. i have about 29 miles since the rings as it doesnt have a plate so i have to drive it around my neighborhood when i can to break in the rings.
any ideas as to why the idle is high or is it just because the rings havent seated yet?
The IAC valve controls air to the throttle body / is what adjusts idle, so I think that's your answer - the IAC valve is commanding the high idle condition.
re: power, bearing in mind the Sporty's are geared for torque vs. speed, power will be less than a sedan (e.g. Honda Civic), just due to the gearing..
i have cleaned the iac twice now with no diff. so why is it high?
1998 Kia Sportage 2WD Base Model
Can you get a vacuum gauge reading?
On 1st gen sportage I check for vacuum leak by unplugging the MAF, if idle adjusts to normal you likely have illegal air somewhere.
i unplugged the maf before the rings and it just turned off. should it do that?
Moderator
99 Kia Elan 1.8L
If the IAC is good, then it's most likely a vacuum leak in the inlet manifold after the throttle body.
Discussion Starter · #7 ·
by that u mean the gasket or the vac hose on top?
r those the only things?
Moderator
99 Kia Elan 1.8L
It could be anywhere and anything such as the gasket, hoses connections, .........., any air drawn in after the throttle valve will cause an increase in idle RPM.
Discussion Starter · #9 ·
can i use gasket maker for the intake tube to the throttle body?
can i use gasket maker for the upper intake manifold to the lower intake manifold?
Moderator
99 Kia Elan 1.8L
You can, IF you confirm that it is "O2 sensor safe" - it should state this on the packaging.
Some silicone based sealants can poison the O2 sensor and thereafter it's trash.
Discussion Starter · #11 ·
the stuff i have is sensor safe so ill go ahead and do that, ill update when i can.
Discussion Starter · #12 ·
well i did the gaskets and no change. could my IAC be bad?
when i unplug the maf the car is trying hard to stay on and it does but barely.
when i unplug the IAC the car revs up till i plug it back in.
Discussion Starter · #13 ·
help plz...
10 Dodge Ram 1500 Quad Sport, 05 Volvo XC90 2.5T, 01 Kia Sportage 4x4 Convertible
Anyone has a pic of where the IAC valve on a 01 Sportage? Sorry new to the Kia scene. Thanks.
Disregard the pic request. I found it, it was looking at me all this time lol
1 - 15 of 15 Posts
