Hello, i am hoping someone can help.
I have an 03 sorento with 250,000 Kms on it. recently had timing belt, water pump, crank sensor, new plugs new wires and throttle body cleaned. The truck has been generally running great.
Recently when the engine is warm and in park it idles high between 2000 and 2500 rpm.
In drive at a stop with brakes applied its about 1100. if i am coasting and i put the engine in neutral the RPM's rhythmically bounce between 1500 and 2000.
My check engine light was on briefly about a month ago but is currently not on. I believe the code we got was P0507 (high idle)
I have extensively read topics about the TPS and the IAC on here. I have cleaned the IAC but nothing change.
I am in a position where i cannot consult a mechanic (due to location) for 4 to 6 weeks so i'm just trying to do some presearch
thank you in advance
