1 - 14 of 14 Posts
2012 Black Kia Rio5 SX w/ Nav, 2005 Honda Odyssey EX
I did not have to install one. I think it depends on the kit. Some kits require it, mine did not.
Have you tried remounting the light? Could it be that it is not sitting in the housing correctly? Just a thought.
RIO5 SX Brenthon
My installer told me that you need a relay if you have DRL that turns on automatic
when you start the car. Since I'm in the states we don't have auto DRL. He did not put any relay.
2004 Optima 2.4 EX, 2005 Yamaha R1 (street) 2001 GSXR 1000 (track)
Hopefully it's a simple fix, as Tony Flags mentioned. I hve seen improper bulb installs cause all kinds of lighting brightness/aim issues. As far as the relay harness goes, I always recommend a harness with any HID install. There are so many threads on this topic, and there is a lot of people that will be in favor of, or against the harness. I would just rather have it so the risk of overheating the OEM wiring is minimized. I have seen the pros and cons of either choice, but this is my preference.
2013 Kia Rio EX
Discussion Starter · #7 ·
While I don't have automatic DRLs no matter what I do the passenger's side will always be less bright than the driver's side. I even reinstalled OEM halogens to see if the problem persisted and it did not. So I took the ballasts out swapped positions and again the same issue appeared so I can safely say the ballasts are not the problem. Thoughts?
Did you try switching the bulbs as well?
2012 Kia Rio 5dr EX
I installed a plug and play kit (6000k) with no relay and I experience this same issue. At first I thought I was just seeing things but the more I look at it, my driver side light is definitely brighter than the passenger side. To the point were one looks 6000k and one looks 5000k. I'm not gonna lie, I did go cheap and that may be the issue. I plan to get a better kit with a relay and see if it still continues.
2013 Kia Rio EX
Discussion Starter · #12 · (Edited)
I'm gonna install two relay harnesses today and I'll let you know if this solved my problems.
1 - 14 of 14 Posts
