Hey guys and/or gals,
I have a weird issue arising with my HID lights.
I installed both HID lights and they worked perfectly for a month with no problems/ no flicker.
Just on Friday I got in my car and started it up turned the headlights on and both cut on and one cut back off. If I put my car in park and press the brake sometimes the light comes back on, and then I put it in reverse and it goes out. I really havent found a solid pattern to the problem.
I have already switched the ballast and the bulbs are not an issue.
Do you think this is a ballast issue or that I need a relay harness? I would think it's a ballast if they worked fine for a month and then started messing up but what do I know I was already stupid enough to buy a cheap HID set, which is probably the first problem here.
Thanks in advance.
Thanks in advance.
