1 - 1 of 1 Posts
Kia Sedona 2011 2.2 manual
Hi I have a 2005 2.9 CRDI manual Sedona.
I drive about 500 miles a week.
I was driving on a motorway and the engine sort of stuttered (lost power for a fraction of a second) then came back. My engine check light then came on orange. I pulled over and stopped the engine. I couldnt see anything obvious so I started again and the light was out. As soon as I got back to 60 mph my light came back on so I drove slowly home.
The bloke who normally fixes things for me said it sounds like a fuel problem so he changed the fuel and air and oil filters and put a diesel fuel cleaner in.
The problem seemed to get worse. I was now getting the judderring regularly and at all speeds (but not when the engine was cold) I put a second hand MAF on.
So my bloke cleaned out everything breather pipes, air intakes second fuel filter intercooler etc. The car seemed to run ok for a couple of weeks then started again, getting worse. I got him to clean again but to no avail.
So i took it to a bloke to plug in his computer.
He told me the MAF was the problem.
I bought another but it still didnt fix it. So I went and got all the readings off the bloke.
This is what he had.
DTC - Description
0400 - EGR drive permanent low level
- Intermittent
0101 - Air mass flow signal permanent low level
- Intermittent
1140 - Inlet air temperature sensor short circuit to ground
- Intermittent
1120 - Rail pressure control valve IMV parameter in upper limit
- Intermittent
1500 - Vehicle speed signal incoherent value
- Intermittent
I have also now changed the throttle position sensor.
Still no better.
Any ideas what I should do next?
Googling some of these codes give different results to what he put.
Any help please.
Ady
1 - 1 of 1 Posts
