I want to replace the hard brake lines going from my proportioner valve to the wheel brakes. What is the size/diameter of the hard brake lines on the 2003 kia rio? I cannot find that info anywhere?
would reccomend taking off that line and taking to an auto parts store. Basically diameter is usually 3/16 or 1/4, but there are many different threads and fittings. So, best to take with so can match up all aspects.
Thanks for the answer, but without going into a long drawn out story, im not going to be able to take it to a store for comparison. Does anyone know the size for sure?
3/16 on my 02 rio if that helps any. Also if the connectors aren't the same get yourself a double flare tool so you can reuse the original connectors if you need to, and a bending tool helps also. Reguards Ronjohn good luck
