1 - 13 of 13 Posts
2003 Kia Rio Cinco 1.6
I have a 2003 Rio Cinco, 1.6.
I pulled the head and intake to replace a couple bad valves. I start to put it back together and I realize I have two almost identical sockets that the Cam Positon Sensor could plug into. Only difference in the sockets are the water tight seals. One is red, the other blue. If anyone could tell me how to determine which is which I would be grateful, I need to have the car for work on Monday.
114559
Take another look at your posted pic. The 2 ends are shaped different so they won't interchange. Look at the sensor end to determine which one goes to each.
They look different because of the angle I'm holding them at. I promise you the plug fits perfectly into both sockets.
2014 Hyundai Veloster Turbo / 2001 Kia Rio
I don’t remember seeing a blue one on mind. What area are they in?
Actually can you tell us the wire colors? The MAF and IAC are both 3 pin plugs ... and right next to each other.
OK try this. ONE plug actually shows from your pic as having TWO wire pins and the other as having THREE wire pins. Look for the corresponding sensor PINS as compared to the plug on sockets.
  • Like
Reactions: rpw00mirage
Discussion Starter #7
One socket is, as marked: 1-Yellow, 2-Green/Yellow, 3- Red/ Green. The second one is 1-White, 2-Red/Green, 3-Green.
Darn PICTURES...well it was worth a try! SORRY! ;)
Discussion Starter #9
Unfortunately they both are three wire. The harness is very much dry rotted (Florida heat) and one socket broke. It's easy enough to replace but that still leaves me not knowing where it goes.o_O
The blue one is for the MAF. I went downstairs and looked... yellow green red.
114564
Discussion Starter #12
Thank you, if the blue one is for the MAF, then the red one would go on the CMP. I didn't want to plug them in backwards and short something out. And for everyone else, yes I know that could still happen but at least now I can make an educated guess. Thank you again for the help.
they won't short out anything. trust me :) lol
1 - 13 of 13 Posts
