anyone with a shop manual mind looking into this for me?
please
please
Axe Man said:The shop manual unfortunately does not describe on HOW to remove the relay.
I've never looked up there but I would suspect there is some sort of clip that holds it into place. See if you can get a spot light in there and look carefully. There might be a steel clip across the relay. If there is you should be able to push it to one side and pull the relay.
