1 - 7 of 7 Posts
Hi guys out there..
Im very confused about my 2010 kia carens.. It has a rattling sound or knockinG sound on my engine.. We replace the oil pump but the noise wont go away.. Many said its my engine, piston ring, main bearing somthing like that.
Is this possible? Or you have any suggestion?
Any one who encounterd this situation?
I dnt know what to do..
Little help pls..
Thnx
2014 Kia Soul, 1.6hdi auto, in Mixx trim, White over Powder Blue
2010 is under warranty, take it back to a main dealer.
Carens 2010... but what is the ODO?
What engine? Diesel? Petrol?
'Knocking on cold, hot, under load only or what?
how about oil?
listen, I strongly suggest to begin with easy=cheap things - oil, some loose parts, bad gas, faulty glow plugs... before you move to piston rings and so on.
Discussion Starter · #7 ·
We also change the oil even the oil pump had been change but still some knocking are still there..
My mechanic said that we try to treat the fuel by putting a liquimoly fuel treatment..
Some mechanic said its sound like a blow by engine some said its totally blow by But im curious because the car runs as same as before as i first use it so how come its a blow by engine? Am i ryt? Even no smoke at my exhaust pipe at all...
Im very confused and pissed of ;(
1 - 7 of 7 Posts
