2002 Kia sporty, couple of BMW's, 2003 RAV 4,
sounds like mine may need some lube or replacement... anybody know the procedure to access the motor?? sounds like it is right behind glove box thanks in advance for any help---- joe
Yes its under the glove compartment . You can access it from inside the car underneath the glove compartment. Three screws an a wire connection an it drops out. Removing the glove compartment door may make visibility better but not necessary. The motors can be taking apart clean an lube but replacement is usually the end result. Clean out all the dirt an leafs while your in there.
chief
thanks
removed fan assy cleaned out all the old leaves lubed the shaft bushings and now it runs like new thanks
