2013 Sportage 2.0 AT FWD
Hello friend. Iam sportage gen 3 user from Indonesia. I have a question about my sportage lamp.
On idle all the lamp become pulsating. Headlamp, foglamp, beam lamp, cabin lamp.
When i measure the voltage, it works normaly around 13.5-14.3volt .
I have done some experince with LED H7:
1. Plug the battery directly, the engine turns off, does not pulsating (LED works normal)
2. Plug the battery directly, the engine turns on, does not pulsating (LED works normal)
3. LED Positive plug the battery, negative plug to HeadLamp socket, does not pulsating (LED works normal)
4. LED Negative plug the battery, positive plug to HeadLamp socket, does pulsating (LED not normal)
Sorry for my bad english. Thanks in advance.
Update:
5. LED negative plug to HeadLamp Socket, Positive plug to HeadLamp Socket, the engine turn off, does not pulsating (LED works normal)
2006 Kia Sportage EX 2.7L
Did the sportage originally have led lighting? If it's a conversion more than likely you need some kind of anti-flicker device, resistor or capacitors.
I'd say start checking connections then. Maybe something is loose or corroded? Look hard at the connections coming off the battery to the distribution block.
You could turn on lights and start shaking wiring.
Do you think it could be the voltage regulator inside the alternator that is on its way out??
  • Like
Reactions: rio-t
Today i have checked below the main engine fuse block, everything looks fine.
Will check for corroded tomorrow.
When i check the battery voltage when engine is running, the voltage is normal. So i guess the error is in the system, maybe wiring between main engine fuse to output (headlamp, beam, cabin lamp etc)
