2006 Kia Rio 5
Something strange that has been happening lately with my 06 Rio. Whenever I put gas in whether I fill it up or not, it hard to start and when it finally does it spits and sputters for a few minutes. Any idea what is going on?
Drives : Nissan NV200 Flies : Rans S6ES
What you describe sounds like the symptoms of a leaking fuel tank purge control valve. When you refuel fuel vapour is pushed through the leaking valve into the engine intake, causing an over rich mixture. The valve is usually located at the back of the engine near the throttle body...
114798
2010 Kia Rio LX
I can vouch for this diagnosis and solution. I had the same exact problem on my 2010 Rio LX, and replacing the purge valve solved the problem AND increased gas mileage by several mpg. It's a <$20 part that takes 10-20 minute to replace using basic tools.
The hard part is getting the old valve out due to its hard to reach location and removing tight hoses. Hose pliers help a lot but are not essential.
Here's the part I used:
Good luck.
